FingerLaker
Thread starter- Joined
- Oct 31, 2018
- 37
Hi all, my 89' Maxum with a 3.0 Mercruiser, that I use not nearly enough (the source of most problems, likely) has run fine for me in my third year with it (previous owner was the town mechanic!), but occasionally, with no consistency, except possibly after a long run time before incidence, just bogs and dies like its out of fuel. 15-30 mins of floating and fishing and it restarts normally. Then its fine, but mostly, of course I tend to head in after that or move to the troller. But its always ran long enough again to get me back to ramp. NOW, this year I was fuelling up for the first time with only about 3-4 gals left in since October; gas spilled back out port after only a couple gallons, and also stuff started spilling out from the tank ventilator thing, with some sort of residue; I figured it pushed most out, but I still had it later when trying to add just a few more gallons. The boat was stored in an open field.
SO: Could this be related to my intermittent fuel supply problem that resolves itself..?! i.e., does ventilation also effect fuel supply to the lines- and how does one thoroughly clean the ventilator thingy to make sure it breathes well and doesn't clog? I am away from the boat again, so I duck taped the ventilator in the meanwhile to keep critters out.
Thanks for any insights any might have.
FingerLaker
'87 Bayliner Capri/85 H.P. Force on the Big Muddy Potomac
'89 Maxum 1900SR/Mercruiser 3.0 on Cayuga's Shining Waters (NY)
FingerLaker
