I have a knock at 4600rpm max throttle every 30sec or so. If I back off the throttle off just a bit to 4500rpm it goes away. It sounds like a rod knock. My guess is that there is detonation.
2004 merc 5.0L alpha one genII 2bbl carb w/TKS, thunderbolt V ignition. Engine only has 160hrs. Compression check last year showed >205 in all cylinders.
I just replace thermostat as it was running too high at about 170F. Now it runs at 160F right where it should be. I replaced all spark plugs and found two on starboard side had cracked insulators. The tips where tan but there was some soot lower down in insulator. This helped reduce the frequency of knock/detonation. I have confirmed the spark plug wires are in correct firing order. When I replace the plugs I left them gapped at 0.040". The spec for my engine is 0.045". So I need to fix that. I plan to check timing is 10deg BTDC next. I confirmed oil level is below max. I confirmed rev limiter kicks in at 4850rpm so that's not the problem. The thunderbolt V has a knock sensor but it does not seem to stop this.
So what should the next steps be? Are there any common issues with this platform?
