Re: Intermittent Miss / Rough idle / Wont Rev - fuel related? UPDATED!!
First of all,
Thanks again for all of your help. I am going to have the fuel pump rebuild kit in my hand on Tuesday AM. Will install it at lunch or sooner, and hopefully head to the lake that evening! I'll keep you all posted!
Fireman,
Honest reply and I understand it fully!
As an owner/operator of a message board/forum of my own for TX Land-based Shark fishing, and any other type of fishing... (
http://www.lonestarsharkers.com ), I've realized that once a post gets enough replies...and nothing seems to get resolved, people tend to move on to the newer posts. This isn't necessarily the case here...but it is part of the reason why I started another thread (habit?)
A LONG time ago, I had bad fuel lines (when I first bought the boat), and I had to pump the bulb to keep it running at times. However, I replaced the entire spanse of fuel lines, every hose on the boat, and it fixed my problem, for then.
Now, almost 2 years later, pull the boat out of the shed and I again have a rough idle/starving situation. I hadn't cleaned or rebuilt the carbs since I had owned it, and wasn't sure if the previous owner did...so I tore it off and asked a family friend (30+yrs OMC mechanic) to guide me through a rebuild of the carbs. That went smooth, and I figured all was well.
First time I ran it on the hose, had the same problem. I went to check spark and got shocked by the plug boot (bad sign). So, I instantly assumed electrical, and posted up. If the plugs wires were arcing, they needed to be replaced either way as the excessive resistance can't be good. So, changed the plugs and plug wires. THEN, I had a starter issue! Go figure. Replaced the starter drive kit, and went to the lake...had the same rough idle/starving issue. It wasn't until the lake trip that i realized that priming the fuel bulb got my idle smoothed out and made the engine run correctly. So, now I am instantly thinking fuel related issues again...although I know I have replaced everything short of the pump. Several people told me they thought it may not be the pump, because it runs good at high RPM. That baffled me as well.
However, Because I NOW thought it was definitely fuel in lieu of electrical problems, I posted up a new post regarding FUEL issues. I figured some people know fuel, some know electrical, and some hate one or the other. All of the fuel issue gurus would hop on and help (and they did), and the electricians wouldn't bother wasting their time anymore. Those who know it all, reply to all of them anyway...new post or not.
And, after all of this, you are probably wondering, So why not go see my friend who is an OMC mechanic?
Unfortunately, that same family friend went into the ER the SAME EVENING after helping me complete my carb rebuilds. He ended up with a ruptured spleen among a few other things, and just got out on Friday (10 days I believe?). I haven't had it in me to call and bug him yet! :$ o
So, I figured I'd post up again...and I think I may have finally kicked it!
In the future, I'll try it all on one thread. But, because my posts tend to be long-winded...if I find something that veers off the original title, I will sometimes start a new thread. Some people don't like to read through it all, but may still have the answer. A fresh topic is sometimes better.
Shawn
PS: Once the problem is resolved (please let it be the fuel pump! lol ), the moderator should be able to merge the two threads without any problem.
