intermittent spark to coil
Status
Not open for further replies.
coroname
Have had several problems trying to find the problem with our 4.3l mercruiser stern drive. Wouldn?t fire - changed the distributor cap, ignition sensor, rotor & plugs & coil. Now only gets intermittent spark to coil. Did fire but died shortly, and then no spark again???
Don S
Re: intermittent spark to coil
See your other post. This is the same problem. Don't start more than one thread at a time on the same subject.
rail
This happened to me after replacing everything you did i found the wire that runs from coil to dist. to be bad it might run it might not I replaced it no problems since hope this helps
Status
