Click here then look under shift bracket.
What are you trying to see?
You didn't Answer Don's Question,.......
What makes you Think it's the Switch,..??..??
9 times out of 10,...... The Problem is the Lower Shift Cable,......
Not the Switch.......
I know I've given you this link several times, and I know you have seen it in other posts.
Open it, read it, save it to your favorites and consult it often.
It's a link to the Service manual for your drive.
http://www.boatfix.com/merc/Servmanl/6/6covr3.pdf
so this link does not really address the switch right?
yes I admit that I do not know where the switch is -- but that is great that you do!I can't find Anywhere in this thread where I see where you've stated Exactly What Your Issue IS.................
Other than you don't know Where the Switch IS, or What it Looks like......
There's enough Links posted in this thread to cover Every Switch ever used by Mercruiser...........
This 1 covers All of your Outdrive,.... Shift Cable,+ Interrupt Switch Included.....
