baseline,
This was my solution to the same problem. I used schedule 80 (outdoor) PVC and a screw in endcap that I drilled out a hole large enough for the oarlocks. Works like a charm. I do have one strap, that connects to an anchor on the inside to the "battery compartment" and I added another anchor to the other side from a salvaged tie down.. I've even used it on class II rivers and it holds up.
Thanks for sharing oldmansivo, that is pretty creative of you to build!
I'm wondering though if there are any other options just to replace the ring with a bigger ring, hopefully there's more people in the same boat
I broke the intex oars where there is a plastic coupler, which is why I'd like to have a bit better oars
