Re: Intex Mariner 4 modifications and Tips
Yes i made a wiring harness, #10AWG ran two times for positive, two times for negative. I dont know what the effective AWG would be, more than likely #8AWG.
When your trolling motor has been on #5 for a while, lets say a minute or two- you should be able to feel the wiring in your palm,- there should be no heat being given off. Heat means the wire is too small, heat is resistance in the wire.
No, i didn't replace the original length of wire to the head unit, the wiring harness is merely extending the wiring without adding resistance, the original 4' or so section of very flexible power cord needs to be retained.
BrianB
When you moved your battery forward, did you change the guage of the wire, by splicing into the old wire on the minn kota, or did you replace entire wire from point of origin to battery? I want about 6 more feet of wire for me to move the battery forward on the Mariner 3 to balance out the weight. I have a minn Kota 40 endura. Do I need to change the entire wire to a smaller guage. Any suggestions from the 12 V wire gurus.
Thanks
