fireman_bob
Thread starter- Joined
- Mar 16, 2008
- 100
Hi, I've got a 2003 Sea Ray sedan bridge 480 I'm working on. I'm putting in an inverter/charger using the 24VDC bow thruster batteries. In the electrical diagram for this boat, it shows the bow thruster motor case and 24v battery B- connected to the grounding bus (green wires), yet I don't see any physical connection nor do I get any continuity from 24v B- to the grounding bus. The bow thruster motor case is connected to 24v B- wire at the motor ( I don't think this meets ABYC requirement?).
I believe the ABYC requirements for inverters specifies the unit's chassis ground needs to be connected to the "engine negative terminal" (grounding bus) and not just the DC B- point which is the 24v battery in this case. Would there be any issue connecting the 24v B- to the grounding bus to meet this requirement? Or can I just connect the inverter chassis ground to the B- connection (without having the B- connected to the grounding bus)? The problem I see with the latter is that if a short from AC line to case developed, it would energize the 24v B- bus and not take out the upstream AC breaker.
