Is a 9 Pitch Prop for 15hp Thru Hub 1975 available anywhere?
KirbyE
Where can I get alternate pitch props?
I have a fine 9-1/2" Dia x 10 pitch on my 1975 Johnson 15 hp thru hub and it runs fine. The boat is heavy and I would like to get the RPMs a bit higher, but the next size in the Michigan catalog is 10" dia x 7 pitch (12112). I think this is too big a jump. The boat just makes plane now, so I only need a little more. I think I need to be at higher RPM. I think I would like to have a 9.5 X 9 or 10 X 9. Where can I get one to fit this motor? Is there any way to modify the prop to behave like a 1" lower pitch? I see OMC 0386670 is 9 x 10 and 0387389 is 9.25 x 8. Are these my only other choices?
Aplolgies if there is already a thread on this, but I was unable to find it. Thanks.
ezeke
Re: Is a 9 Pitch Prop for 15hp Thru Hub 1975 available anywhere?
A really good 4 blade aluminum 10 X 9 was made by OMC Part Number 176266. Great for heavy loads.
freddyray21
a prop shop can repitch that prop as well.
tashasdaddy
here are the recommended props
0386118 PROPELLER,9-1/2x10 (std.)
0386669 PROPELLER,10x5
0387389 PROPELLER,9-1/4x8
0386670 PROPELLER,9x10
ezeke
176266 is a 10 X 9 OMC/BRP 4 blade aluminum prop still made and sold and available through any BRP dealership. It is suitable for high thrust applications and for your motor and for any other through hub 15 or 9.9 from 1975 up.
CATransplant
You're right. I just looked that one up on ishopmarine.com and they have it in stock. They also show a list of all the props for that model...more than I expected. Nice range of props with application suggestions there.
KirbyE
$$ 186 !!!! Holy Cow !!!
ezeke
It's only 164.29 list price at the BRP store.
