1989 Johnson GT 150
I recently rebuilt the carburetors and set the float height level with the carb body. The float drop was set at 1" which is the middle of the specification.
The engine is still smoking like it is on fire. I am running it on a remote tank with a known ratio of 50:1. I checked the primer solenoid/enrichner to see if it was leaking. I also checked the VRO pulse fitting by pulling 15 in/Hg vacuum and it did not leak. How can this engine be running so rich? Do I really need the OMC gauge to set the correct float height? It seems like that is the only thing that it could be.
Thanks
Thanks
