SS may give better performance but if your lake has a lot of rock bottom I would stay with Aluminum. A relatively inexpensive Aluminum prop will often self destruct before transferring the force to your drive shaft and beyond.
Here in the Ottawa (Canada) area, the lake levels have fluctuated a lot in the past several years and two of the guys I water ski with have damaged their lower units by hitting rock with a SS prop in areas where we did not expect shallows.
I've run a 3 blade stainless on an 18' bay boat with a 115 Evinrude since 93'.
I use stainless exclusively because the prop is constantly drug through sand.
Thinning blades (which can usually be repaired bt Nettles) and spun hubs have been my only problem.
Switched to a 4 blade last year and wish I had it from the start. The hole shot is so improved I can get up 6" shallower than before. Lost some top end but worth the trade.
Personally I found no difference (except the cost) on my 115 hp cuddy.
Stainless vs aluminum -- diesel truck vs gas...whatever makes you happy.
See this is why I found it not easy to make the decision to go SS - you say you found no difference - others said they have good results - I guess it always depends of the boat combination with engine - hull type and +++
In other words you never know how good it will be until you try a SS prop.
I tried 15 different props and ended up running the 3 blade aluminum that came with the boat.
Solas makes aftermarket replacement props for OEM applications only.
