Is it normal for water to come from these holes?
rallysman
I'm helping a friend and have no clue if water is supposed to come out of the holes pictured (when hooked up to muffs). Any help is appreciated. Thanks in advance!!
rsimmons42
Re: Is it normal for water to come from these holes?
completely normal
freddyray21
normal. it comes out when in the water too you just don't see it. the cooling water comes out with the exhaust and out the prop and those relief holes.
5150abf
Yup, I about had a stroke the first time I changed a water pump, it seemed like water was coming out everywhere and I was sure I screwed something up.
kenmyfam
Completely normal. Gives you wet feet the first time though if you are standing next to it when someone turns the hose on.
rallysman
Thanks! I appreciate the help.
1946Zephyr
These holes are there to let the water drain out form the lower unit, once it is out of the water, therefore preventing standing water from freezing and breaking your lower unit. Always make sure that these are clear of any obstruction and they drain freely.:cool:
Mas
It is also suggested in the "owners manual" to cover the vent holes under the cav plate with tape or other to ensure the proper function of the water pump while on muffs.
I do not do that because I always fear to would forget to uncover them.
MAS
