Is it okay to (post glassing deck cleaning question)
bear_69cuda
Is it okay to hose down the engine, bilge area, everything... Just wash all the grinding debris, dust and crap out the drain? Should I be concerned about wiring harness, trim pump, or any thing else? I basically want to hose out the entire boat... (I will cover the carb) Any recommended general purpose cleaner/degreaser for engine and bilge? Simple green?
Obviously my effort at covering the engine did not work well... :(
mthieme
Re: Is it okay to (post glassing deck cleaning question)
I do it every spring. I use Gunk. Depending on the age and condition of everything, it is not impossible to have a problem or two afterwards. Avoid direct contact with the distributor. Even better, put a plastic bag over it as well as the carb.
Bob_VT
Try some S100 Motorcycle cleaner ....WOW is it good stuff and will not hurt wires and stuff. You spray it on and hose it off and it does a great job. I have used it on motorcycles, atvs and car engines.
