Buster_boy
Thread starter- Joined
- Aug 9, 2015
- 178
I want to get a bit more buoyancy on my boat. I thought if I could add valves I could do that.
Thanks
Thanks
Pressure does change the buoyancy, the higher the pressure the less buoyant the pontoon will be, a vacuum would allow maximum buoyancy. The more air (any gas) you cram into the pontoon the more it will weigh.
Purging the air and filling them with helium will increase buoyancy, only because helium is lighter.
ondarv.n, Technically you are correct, but realistically, not so much. The actual change in how deep the pontoons would sit in the water wouldn't change any appreciable amount either way. While you are technically correct, it seriously wouldn't be worth the cost or effort to fill them with helium. If you really want to get that technical, the ambient temperature can change their buoyancy from day to day as well. But not to any amount that would be noticeable. So in general terms, it doesn't matter. If he wants more floatation, add another toon. JMHO
The question - "Is it possible to install air valves to my logs?"
The technical answer is "Yes".
The practical answer is "Don't bother".
They still do it and people still fall for it. I call it snake air!This question reminds me of the Nitrogen scam that tire installers used to sell. When getting new tires, they would actually sell people on the advantage of adding nitrogen to their tires instead of "normal" air and claiming all sorts of benefits. The charge? 10 to 20 bucks. Dumb.
And it doesn't take much pressure to burst a pontoon. Do a search on the forum and someone posted a picture illustrating what can happen. Seems to me the tubes are tested at less than 4 psi.
