dingbat
- Joined
- Nov 20, 2001
- 17,238
Re: Is it safe to store boat in garage w/H2O heater???
In comparison, I now heat 4,500 sq. ft. with a ?high efficiency? forced air oil burner. We stayed in neighborhood so the climate data is the same. My heating bill last year was almost $3,000 of "fossil fuel".
Converting to heat pump with oil backup in the next couple of years. One caveat. The home above was built to 90's sealing and insulation standards. Our current home was built to late 70's standards so the home's "efficiency" is a factor.
Please explain why you can?t use one in the south? My parents use a heat pump in Tampa they are very happy with.
Been there don?t that. I ran a heat pump with resistance backup in a 3,200 sq. ft. home for 20+years. The most I ever spent heating that house for the winter (5 months) was $1,400, averaged closer to $1,200 during the typical winter. I will concede that our daily average highs in the winter (Baltimore/ DC area) are 50 degrees and an average low of 34 degrees so near perfect conditions for the heat pump.Dingbat, You do realize that chart is proproganda. Heatpumps are simply central air conditioners, that can work in reverse in the winter, "pumping heat" instead of pumping cold air. They are only suitable in moderate climates, because when the ambient temperature falls below 32*F there is not enough "Heat" to pump. Most have supplemental electrical resistance heating for those days. You want some expense, heat your house with electrical resistance.
Heat Pump Systems | Department of Energyfor example, a heatpump is using electricity to heat water. Since the cost of generating electricity is already a minimum of 36% more than any fossil fuel, running the heatpump compressor to produce heat would need to cost 36% less than directly heating water with a flame. I do not see how that is possible, given EER ratings of air conditioning systems
Because they move heat rather than generate heat, heat pumps can provide up to 4 times the amount of energy they consume.
Heat pumps may not be feasible up north for now but the popularity of geo-thermal systems is on the rise. The performance of my neighbors system is pretty impressive.That chart has probably been skewed to show a climate perfectly suited to heat pumps. It likely does not apply to anyone in the north or south. Remember "there are lies, there are damned lies and then there is statistics".
