harvey5560
- Joined
- Sep 15, 2010
- 26
Hello,
I have a 2006 50HP Yamaha 2 stroke outboard which I purchased last year. So far this season it has run great ( 35 MPH on my 16 foot aluminum) which is what is expected based on the published yamaha performance specs.
However, this past weekend I was only able to get up to 25 MPH both with the wind and against it in relatively calm waters. The motor started up right away, idled smootlybut didnt seem to be running on 100 percent power. RPM appeared to be about 15 percent less than I usually see.
When I purchased the boat last year the carbs were pulled and cleaned. Prior to storage I filled the tank with fresh fuel and used the recommended amount of Sta-bil marine.
Could this be the carbs or is there something else I should check?
Thanks
Thanks
