Michigan Jason
Thread starter- Joined
- Jul 12, 2010
- 154
Ok, let me start by saying that I am an idiot. I knew the cold weather was coming and still insisted on using the boat a few last times. As Michigan weather does frequently, it changed on me, and fast. We had weeks of 40 degree weather and the week I headed to Pittsburgh for the Lions game I knew it was going to be close to if not freezing here. I chose to place a light bulb in the engine compartment of my Regal valanti 202se. I also grabbed one of my cheap BBQ thermometers and placed the temp probe inside the engine bay as well. After monitoring the temp to hold at a low of 37* I deemed it safe to go on vacation and winterize when I got back. According to the temp probe the temp never got below 37* but I still had a bad feeling when I came home so I checked it. When I moved the probe, the temp changed and jumped to 60*! At that point I basically started crying. I put the boat in the garage, and uncovered it, sure as hell my upper water hose was frozen solid (typically I can squeeze it and hear water sloshing around the engine) So I added another bulb, and let the boat sit in the garage for over 7 days at a temp ranging from 47-60* Finally got the balls to go outside and see if I got lucky or not, and upon placing the muffs on and starting her I felt great! It was running, and sounded normal, until I looked under the engine and watched water coming out from all over the place. I turned it off and tried to see where it was coming from to no avail. Started it back up to take a video and then gave up deeming it totally useless. Now I am wondering if it is possible that I did not crack the block and maybe the water was coming from somewhere else. I since just left the boat outside and gave up on it. Didn't even bother running the rv antifreeze through it because it would all just end up in the bilge. It was all clean water coming from the motor, I did not see any oil or anything like that. Just water. Here is the video.
Does anyone have any positive news for me? As of now she is sitting in the 15* michigan weather where she will sit till spring.
What happens when you don't winterize your boat.(2) - YouTube
Motor is a ford 5.0
Motor is a ford 5.0
