Just got a '56 Evinrude Big-Twin. I didn't pay a lot for it and have done some looking over and cleaning while going through "Awakening a sleeping outboard; by BoatBuoy". After inspection I have found some issues with the motor and I need to know if it is worth continuing with repairs or if I should just forget about this motor and use it as parts for another (and practice
Here is what I have found on inspection:
I have done a compression test, around 20 psi on both cylinders.
I used a spark plug tester and there is no spark being generated.
Shown below on the lower unit there is a crack that is leaking gas/oil mix? I don't know why?
The gear box in the lower unit is leaking oil out of where it splits in half (bad gasket?) and is also leaking oil out of the water bypass cover (not sure why?). The pull start is missing the pawls and some small hardware
The tiller handle is broken off however the controls still work.
I know you guys have done lots of work on these and would really like to have your opinions. I have posted some pictures of the motor for reference.
