HalfFish5087
Thread starter- Joined
- May 30, 2012
- 278
Re: Is it worth it? '98 Larson 5.7GS DP Lower Transom Rot
Thanks spark! It was a battle I was dealing with before this restore was started. I had multiple fits that were getting worse and worse, eg it would start and run great for a couple hours and then all the sudden she would be really hard to start, after lots of pumping or would not start at all, without pouring gas into the carb and priming the system. Anywho, I relaced the pump last thursday night and so far (knock on wood) so good!
I just finished a transom rebuild and had fuel issues when I got everything put back together. My problem ended up being some small fiberglass chunks got into my fuel tank fill line. When I added gas to the tank, it ended up flushing into the tank and getting picked up into my fuel lines. I found it trapped in my anti-siphon valve and restricting the fuel flow.
By the way, that is a GREAT looking boat. Glad you decided to restore her.
