Re: is my alternator big enough for this?
If the alternator is the same as on a 90 HP outboard, I believe it is a 18 amp unit. The question is not so much will the alternator handle it as much as will the battery handle it. The battery is more than likely a rather smallish starting battery so you are down on power on two of the three categories right from the git-go. Battery size, battery type, and alternator capacity determine whether this will be an acceptable situation. The starting battery will not likely last long. Look at it this way. If the amp drew 20 amps to be conservative, and you ran it for an hour (provided the battery lasted that long) you would need to run the boat wide open for over an hour to charge the battery reasonably close to full charge. Now -- does that sound like a winning situation?
