jimmbo
- Joined
- May 24, 2004
- 14,688
The Fly in the Ointment, is what is the Airflow capacity of the OEM Carb and the Characteristic of the OEM Intake. If the Intake can flow more are and the OEM carb was the restriction, then yes the Holley would improve the power. If the Intake is the Restriction, then a bigger carb, will introduce problems unseen before.
I was lucky, Volvo put a very nice 4bbl Intake on my 5.7 and put the 2bbl 500 Holley on an Plate to make it fit. The 5.7 needs a bit more airflow than the 500 can provide, well it can provide more, but the Pressure Drop is too high.
I did put a 650cfm Holley Spreadbore on, and gained about 500 rpm, which required more prop to keep the Rpms within the WOT range. The Holley is a Vacuum Secondary Carb, and the Secondaries have never opened fully, as it still more carb than a 5.7 at 5000 rpm needs. More Pitch also reduces Holeshot, even though the engine makes more HP at the top end, low rpm performance suffers. The very small Primaries on the Spreadbore do help retain some low end Torque. Overall I gained 6 mph which put boat deep into the mid 60s
