nwcove
- Joined
- May 16, 2011
- 6,293
Re: Is my motor/prop too low?
your top end speed isnt bad, but imho, you arent getting the full potential out of the motor due to the trim angle....the motor is working hard pushing the hull into the water rather than letting it skim across the water. how you approach the fix ( or enjoy it for what it is) is up to you.
That seems to be the consensus, but I'm not sure what my options are unless I lock the motor in the correct position, or add a wedge/shim under the motor bracket. It seems to me that there ought to be a simpler solution, unless this boat and motor just weren't made for each other.
