Is my prop shaft toast?
xyzzy42
The thrust holder behind the prop was corroded on and the top was falling apart. I eventually go it off, but it took some doing. I fear the prop shaft took a little collatoral damage. The new thrust holder seems to fit on ok. This picture of of the worst part. Shaft ok or should I replace it?
pvanv
Re: Is my prop shaft toast?
What make/model? I would change it so that you don't get the new prop thrust bushing jammed. But even if you don't it should work OK.
xyzzy42
It's an 8HP Tohatsu, MFS8A3. If the only danger is that I'll have to cut the thrust holder off again, I can probably replace a dozen of them for what it would cost to get the shaft replaced.
jim765
looks a little twisted to me, if i were doing it, i would spend a little more money and replace shaft. had same prob and didnt replce shaft, bad mistake. just a thought.
Sea Rider
If the shaft is not bent, with a dremel, flat out all damaged spline area as seen on pic, grease well shaft before placing prop back in.
Happy Boating
Thalasso
I don't think the shaft is twisted. If it was twisted you would be replaceing alot of parts. Just as
Sea Rider says clean up the shaft and go boating.
xyzzy42
The damage is mostly from my initial attempts to get the thrust holder off with a hacksaw and a punch. If I were doing it again I would be able to do it a lot faster and with little damage to the shaft.
I don't see how the shaft could be twisted, so that the splines are running in a spiral rather than straight. So maybe twisted just meant bent? I don't think it's bent. It would be easier to tell if the whole shaft was out, but I don't have the tools to do that.
The new thrust holder seems to slide on and off just fine.
