1970Thunderbird
Thread starter- Joined
- Dec 24, 2009
- 111
Hey all,
I recently replaced the trigger, stator and internal harness on my 1978 Mercury 800. It's mounted on a 1970 Thunderbird Seminole. I was pleasantly surprised to discover I was getting close to 5300 rpm out of the motor at idle. I thought I was ready to really fly across the water.
Wrong.
A few facts for you:
*The boat is a cathedral trihull.
*It weighs about 1,000 pounds empty.
*With motor, fuel, batteries and people, it probably is close to 2,000lbs.
*The motor is a '78 Mercury 800, 80hp.
I had it out today, testing it out. Here's what I discovered.
*When I put the motor in forward, it will sometimes die. I have to baby the throttle to keep her running.
*I can't smoothly go to wide open. I have to baby it a bit and it tries to die on me, so I back it down. only after a few minutes of this can I go to wide open throttle, even if I've already been running for a while.
*At WOT in forward, the engine runs at 2,500 rpm, about half of what I expect. If I turn sharply, the prop starts cavitating and the motor revs much higher, up towards 5,000rpm.
I'm currently running a 48 72762A4 19p prop. I take it it has a 19 pitch? I don't know much about the prop. It was the prop that was on the motor when I purchased it used. My boat originally had a Chrysler outboard. I looked the prop on it and it has 13x14 stamped on it, which I take to mean it's a 13" diameter prop with a 14 pitch.
Truth be told, I'm a little lost. I'd try just using the prop from the Chrysler, but it won't fit. Do I have an engine problem, or am I just trying to push a prop that is too "aggressive" for such a heavy boat?
I'd like to pull a skier or tuber. Maybe two if I could. Also, the boat will be used for general cruising and fishing.
One more thing: I decided to have all three passengers wait on the shore while I tested something. With their weight out of the boat, it did move noticeably faster, but not full power, by any means. And I still had to jockey the throttle to get there.
Can you wonderful sages help me? If you think it's the prop, can you recommend a proper replacement? Or should I make my way back to my usual outboard troubleshooting forum?
Thanks a ton!
Wrong.
Thanks a ton!
