fixmyevinrude
Thread starter- Joined
- Sep 18, 2008
- 205
Tore down 94 evinrude 200. Sleeve is gouged and cracked. I can see that some of the aluminum block behind the sleeve and below the exhaust port is cracked and broken away. Looks like the piston ring pin backed out and did some major damage in cylinder. Will a small amount of the aluminum support webbing behind the sleeve hurt anything if it is ground away and resleeved? Tried to post some pictures as attachments but the files are apparently to large. Thanks for any possible help.
