Re: Is Schematic in the House ?
Ok, here's how it went this weekend. I started testing the voltage at the soelenoid it was fine there, also down at the motor, and it was fine there as well; took the casing from the motor and found the spring holding the down side brush was rusted and broken, thus explaining why the up worked fine and the down sporadically. Cleaned the whole motor, brushes, etc. with some contact cleaner. Couldn't find the exact spring, so I had to make due with a similar one, but was hard to get the same amount of resistance. Put it back together , and it took several times as it seemed like the armature was binding. Finally, appeared to work great,put all back together and it kicked butt ! Ran it up and down like it was new. Naturally, since it worked, I had to put her in the water for a run, again, worked great trimming up and down. Then, at some point unk, the down tilt stopped working, but the up works great. I don't even hear the click at the soelenoid for the down side. When I do the manual release to let 'er down, hit the up switch, and zips it right up. Doesn't sound like it's binding or anything, but how can I be sure. I plan to test the voltage again at motor and soelenoid, but I assume it has to be either the switch, soelenoid, ord the spring that I replaced. Any more suggestions ???
