Plainoldguy
Thread starter- Joined
- Jul 10, 2018
- 26
I installed a 1983 Force 85 HP on a 1974 Starcraft that originally came with a 1974 65 HP Johnson. Both motors had a 2-wire connection to the tach/ground. After installing the Force, I hooked up the purple tach wire (and ground) to the two connections for the Starcraft tac/ground. It works (meaning it goes up and down with the throttle), but the readings seem way too high. For example, at idle in neutral (using muffs), the tach is showing about 3,000 and it rises much high higher in forward/reverse gear when the throttle is increased. Does anyone know if the two motors have similar technologies that would make this tach compatible or are the readings too high because the two motors calibrate differently? Both motors have three cylinders.
