is there a fuse on my 98 4 stroke J15 with a rope starter?
Silvertip
Re: is there a fuse on my 98 4 stroke J15 with a rope starter?
with a rope start, probably not. why are you asking?
cemiiii
same thing i've been working on, that is, no spark, despite cut off and coil checking out ok. been quoted a 5 week time slot at my local shop! what recession?
Silvertip
If there is a fuse it would probably look like this one (it's a Merc but fuses are fuses). If you don't see it, its in the little box with the word "Fuse" on it. Sorry -- I couldn't resist that.
Boat safely!
cemiiii
thanks for that, but with the other 2 big things in that picture missing on my eng. (Starter and Solenoid) it would not be unexpected that there wouldn't be a fuse there either.
boatguy823
no fuse but you would probably want to check ignition module, stator, charge coil and sensor assembly as well as checking all grounds. If you don't have one you'll need to get a service manual and a digital multi meter with a peak volt adapter to check for proper voltages etc..from the above components.
