Re: Is there an easy way to change lower unit oil?
Hi rwc1965.<br />Welcome to the board, or.... welcome aboard mate.<br /><br />You should be using "Outboard lower unit gear lube".<br />Sold at every outboard dealer, most farm and home type stores, auto parts stores, and some hardware stores.<br /><br />Make sure it is labeled for outboard or lower unit or marine use.<br />This lube is specially formulated not to foam if water gets in there.<br /><br />Most stores will also carry a "Type C" lube, you don't want this one, its for some older motors.<br /><br />For easier use by everyone one the board, it is better to "add a new topic" to ask your specific question, rather than adding on to an existing post.<br /><br />It will be easier for you to find the answer if you know to look for the post that has your name after it.<br /><br />Feel free to ask any other questions you may have about your new boat and motor. <br />Happy boating.
