doberman-guy
Thread starter- Joined
- Jul 19, 2011
- 33
I have a 1980 230hp 350 omc. On one side of the engione the bolt you remove to drain half the engine block is rounded off so bad its impossible to remove without drilling it out. I cant drill it out at the angle its at either. I tried all the lubricants out there, the head of the bolt is just to rounded. Is there another way to remove most or all of the water from that side without removing this bolt? Is there a hose i can remove and use airpressure to push it out? The block is empty at the moment but to run and fine tune the engine I need to run water through it.
