is there really no voltage regulator/ rectification on my 1990 E30ELES ?
swing
theres is a stator and a pack under the flywheel & voltage spikes over 24 volts at mid throttle...
just doesnt seem healthy for the battery or the pack to see that kind of unregulated spiking....
There is a rectifier but no voltage regulator.------Find it hard to believe you have 24 volts showing.
F_R
16 volts is to be expected. 24?? That would indicate bad connections, especially at battery terminals. Continued running like that can destroy the rectifier. Clean them shiny bright and make sure they are tight.
If 16V bothers you, there is a regulated rectifier available, by CDI.
EDIT: I may be mistaken on that. The regulated rectifier may not be available for that engine. If it is, the CDI part number will be 193-1778 (non-regulated one is 153-1778).
In any case, there are thousands of boats running around at 16V-- including mine--with no problem.
