saltfisher
Thread starter- Joined
- Aug 22, 2007
- 111
I think this is a pretty good deal considering what people are buying the motors for in good shape. here is what it is and a picture....
1988 18' tournament series BassTracker FIBERGLASS bass boat
1988 Mercury 150 Black Max power t/t
Jack plate
SS predator prop, and aluminum prop included
Foot controlled 46lb thrust trolling motor 24V
2 fish finders, 1 flasher in the dash, 1 newer LCD display up front
Bilge pump, livewell, t/t, lights, everything works
Motor was only used once per week a year for the past 14-16 years as he only used the boat in canada. Before every winter the motor was fogged, and had maintance done to it. Compression test came out good-excellent!!
Carpet is in great shape, seats are in good shape, except 2 smaller parts in the front need redone, no big deal there...
Trailer has some rust on it. Im going to grind the rust off and repaint with cold galvanize and repaint black. Again i work at a trailer company, no big deal there either...
Boat... Has oxidation. Again..... no big deal as that can be buffed out. Again... another free fix.
$2500 for it all. how does that sound? Motor is very clean, i would rate the appearence a 9/10. barely no scratches, clean inside and out. Looks like you could eat off the inside. Started on 1st key turn from last year.
Here is a few pictures, sorry for quality but you get the idea. I figure the motor just needs a water pump impeller, and batteries to be water worthy. Everything else will be minor TLC and can do myself for free since i have everything. let me know what you guys think.... Thanks!!!!!
Jack plate
