Is this a venture17
I have a 16 ft or so swing keel with a scratched in hin number starting with cyt. It is a hinged pop top. Two large hinged cockpit hatches. NO winch. Only hole with small pulley. Never seen this. Any ideas. No paperwork
GA_Boater
The small hole and pulley are for raising/lowering the keel.
No paperwork most likely means a swing keel yard planter.
Before i plant flowers i want to get model and /or manufacturer. I understand its for the keel but didn't ventures all have winch attached to board across?
GA_Boater
None of the 17' Ventures I've been on had winches.
southkogs
Venture was a MacGregor boat, wasn't it? MacGregor's MIC code would be MAC or MGG. If your HIN starts with CYT that's the MIC code for Cobalt boats. Whom I don't believe ever built sailboats.
Winch obvious as is lack of bench hatches. I will post more pics tomorrow. Windows are also smaller
I agree. I looked it up also. I will post number tomorrow
southkogs
Do you have a true ballast swing keel, or is it just a centerboard? That setup wouldn't be unusual for a centerboard, and a 16' boat wouldn't necessarily need a true swing keel. The cam cleat kinda' suggests there wouldn't be a winch in that rigging (at least to me).
Hmmm. You might have something there. Boat was delivered today ( it was a freebie) and shoal keel is resting on center trailer board so i cant see it until i lift boat up. I also couldnt find any big obvious pivot bolt inside cabin which would support your idea. I should of posted more pics. Someone has to recognize it. Hin ends in 77 so suspect it build year
These should be enough. Once i find out what it is i will be looking for rigging, mast, boom, rudder
southkogs
Mast boom and rudder won't care what kind of boat they're on ;)
I don't recognize it at all. Kinda' looked like a Chrysler, but nothing jumps out. Did it have it's sails with it? Replacing all of that rigging won't be cheap. You may find a mostly ready to go sailboat for similar money.
I understand. I have rescued and rebuilt a few before. Mostly Pelicans, couple vagabonds, a neptune and gloucester. I am a terrible sailor but cant neglect potential on an old crappy free boat Labor of love. Never get anywhere close to time and money i put in. Keeps me out of bar!
southkogs
Oh cool ... and good on 'ya then. Enjoy!
I looked up a few things, the Buccaneer was the first. But I don't think it matched that. Keep posted if you figure out what it is.
So here is the number on the rear transom right side?
