Is this fuel consumption normal?
j_k_bisson
Just asking a question about this motor fuel burn rates.
I have a 1987 225hp Evinrude outboard on a 1991 Bayliner Trophy 21' Walkaround. I have recently rebuild and repower the boat with this motor. The boat had a Force 120hp on it before. I have been running the motor since rebuild and have been logging my fuel burn/purchases. I am figiuring that I am getting 1.4 mpg since the 10 hour mark after rebuild. This rate of burn is running in small, less than 1', to moderate waves, 3'. I will admit that I have been running it at 3/4 to full throttle while I have been doing this study.
I know that boat weight, wave height, sea conditions do make a difference. Just wondering if this is in the ball park for what I can expect. I do have the pitch of the prop down a bit from what it could be with some jet tunning. But what is the max I could expect in gas milage for this motor?
The reason for this question is I basically fish offshore freshwater in the the great lakes. (Lake Erie) My destination is normally 15-25 miles offshore one way. A days fishing has gone from 20 gallons with the Force to 45-50 Gallons. More than double. I under stand I am running double the HP. But I would like some other people experence running these motors for fuel consuption rates.
wilde1j
Re: Is this fuel consumption normal?
You can expect fuel burn to be ~ 22.5gph @ WOT, less at lower power settings.
clemsonfor
my 150Gt 1990 motor on my javalin sucks fuel. I cant hardly stand it. It should be 15gallons/hr wide open well i run at like 3/4 throttle and seem to use that much fuel alone. I think my prop needs to come down some though.
daselbee
I get 2 miles per gallon, average idling and running around 3500 rpm.
Scubaproh20
My 40hp lark with my 14' rowboat gets 2.5mpg and my 14' rowboat with a 9.9 or 15 evinrude got about 3mpg unlike a car our boats are lifted up through a lot of resistance and our motors output is constant at high rpm with no overdrive :) all you can do is polish the bottom of that boat and get the best stainless prop money can buy. Or you could put an automotive carb,manifold and intake/exhaust on. But that's not what the coast guard or sheriff likes, something to do with boat fires ;)
w2much
21' Striper with 1995 Evinrude 150 HP gets about 1.5 miles to the gallon average. 2 miles per gallon in flat sea going downswell. Yours is about right.
