Is this gypsy worn?
Wave34
I have my rode slipping once in a while while retrieving my anchor.
To me the teeth of the gypsy look worn. I would like your advice.
If they are worn, can the gypsy be flipped sides?
Can the teeth be rebuild? (welding and grinding?)
Edit: it is a Lewmar winch, but I don't know the model nor the capacity.
Click image for larger version  Name:	gypsy1.jpg Views:	1 Size:	1.23 MB ID:	10793640Click image for larger version  Name:	gypsy2.jpg Views:	1 Size:	1.19 MB ID:	10793641
QBhoy
More likely the clutch. Advice is to adjust and clean regularly
Tassie 1
Wot 'e ^ said,
son had a similiar issue with his lewmar, different model,
tightened up the clutch and " normal programming resumed "
Wave34
When this happens, I can see the gypsy turning and the rode is not catching, it isn't coming in.
QBhoy
Exactly what happens when the clutch needs adjusted. It’s like winding in a big fish on a rod with the tension wound right off. Never going to happen.
Wave34
I see. It's my first boat. Is there a service manual I can refer to to learn how to adjust it?
QBhoy
I’m not sure. I know about the lewmar ones. Not sure what you have. I do remember seeing a video on you tube once. It’s oretty easy and I think they will be mostly the same. It’s just adjusting the tension on it really.
