Hi, I just recently purchased a 1998 mercury 9.9 EL. I had a new water pump installed in it because I didn't know how old the one that was in it was. I have not run this motor on the water only in a tub of water. My question is: The water that comes out of the tell tale comes and goes. It will pee a steady stream for a few seconds and then it will just kinda sputter out for a bit then start a steady stream again, etc. I pulled out the thermostat and heated it in a pan of water and it appears to be working. Do i have anything to be concerned about? Thank you for any advice.
