Is this wiring for Tachometer
Frank Acampora
Re: Is this wiring for Tachometer
That looks like the mounting post pattern for most tachs BUT------
You need a 20 pole tach and the only one I know of is sold by Teleflex, 0-8000 red sportster series. I don't know if you could find a stock tach for the boat.
If you can not use the molded plug, the purple wire is tach signal, the black is ground and the white would be power from the "I" terminal on the ignition switch.
Bigprairie1
That is the right harness plug to fit the standard Force tach. What size is the hole opening that you have in the dash? (3-1/4"?? or?)
BP
