is water here normal?
cooter2506
I was just running my boat again it is a 5.0 mecruiser with a Alpha one drive. I am getting water out two holes at the bottom of the gimble housing. Is this normal or should the water be coming thru the prop? Sorry if terms are wrong but im very new to this boat stuff
stevieray
Re: is water here normal?
Normal. Running on muffs you should see little or no water out the prop - just exhaust.
cooter2506
ok thanks like I said im new and ask alot of dumb questions, but I guess the only dumb question is if it is not asked. Thanks for the response
SuperNova
Don't worry about it. Just remember: "There are no stupid questions, only stupid people". :D
WAVENBYE2
Mine does the same, exhaust out of prop,water out of gimble housing :D
SuperNova
If you give it a little throttle, you'll start seeing more of the water come out of the prop if that's what you want.
Stan
