Re: ISA network card?
I'm glad you found what you need. As for the older non-plug/play cards, some may have had a software utility to set the port address and irq and save those settings in nonvolatile memory on the card. When all was said and done, you'd still have a 10Base-T card, not that it matters in some installations, but why go slow when for a few bucks you can get better throughput.
That dongle should work just fine in the USB 2.0 slot, it should downshift to the 1.1 spec anyway. As for the USB 2.0 card, you'll see big gains in data tranfer rates (over the USB 1.1 spec) if you connect an external HD etc.
