bbfourwinn
- Joined
- Mar 25, 2008
- 16
I am a first time boat owner. Just bought a '96 Four Winns 200 Horizon and have a couple of questions:
1. The trim indicator does not work. Where do i start?
2. Engine temp gauge seems to be sporadic. It runs around 120 even after running a while at higher rpm's. It will climb to 150 occasionally. Is this normal?
3. There is a slight knocking in the outdrive (transmission?) when in neutral. Seems to run fine in gear and under a load.
4. I know this is not an engine questions but the walk-thru glass does not shut because the opening isn't wide enough (I think from hanging in a sling lift for 11 years). Is there an easy fix?
Engine mod - 50FAPNCA, SER # T01290298
Transon *** mod # - 3868413, SER # T00367816
Drive Unit mod # - 3868388, SER # T00802946
5.0l fuel injected
Thanks for the help!
5.0l fuel injected
