FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
OMS pump failing maybe ???
The good thing is it is using more than enough and not giving you lubrication problems at present. Make sure the tank or oil lines are not leaking into the bilge somewhere though. If not change pump or convert to premix.
Your VRO pump probably needs a rebuild, probably a hole in the diaphragm. There are some test in the OEM manual. Your BRP dealer will have a listing of the rebuildable pump kits.
Thanks for the help. I pumped up the gas bulb and started to see gas leak from the top middle of the vro pump. Looks like it is on the gas side. I think I may need to replace the whole pump.
