"It Happened!" Transom has to be replaced! (NOW W/PICS)
Jcris
No offense stump. But LX has maintained his "just do it" tack from the beginning. I'm just trying to accept that and offer what little help I can.
Jcris
Stumpalump
Jcris
We all are. But when you get "Your not here to Bla Bla bla" you feel a little burn. I'm just so glad he had a cold when I was stuck in Tampa for three days while the wife was on buisness. Wanted to help him move that carport and would have run that grinder or sander for a couple of days just for somthing to do. Now it's sounding like we are just helping a craigslist flip.
jbcurt00
Agree to disagree fellas, or refrain from posting further
Safety/reliability concerns have been raised
The OP admitted he knew he'd get that flak for it and proceeded as he saw fit.
Just a reminder: it is a public forum, not all advice will be what you want to hear and not all advice will be heeded.
LX Kid
Ensign
Whats the haps?
Hey! Been raining and cool weather moved in. Wifey got sick when took GS Troop camping last weekend. Tomorrow will be around 73 and so I'll be back at it tomorrow. Old farts gotta be careful.
LX Kid
Ensign
No Title
With the help of a friend, I was able to mount the gimbal assembly to the gimbal mounting plate. As the pic shows, I used the gimbal plate with fender washers to mount it to the two lower studs instead of just using fender washers over the holes.. No I did not have it welded up! Anyway I'm making some headway.
LX Kid
Ensign
Could have, should have, would have already cut off the old motor mounts, while it on the engine stand, but "I" didn't so I guess that will be the next task. I want to get the engine back in the boat before I start putting new seals in the outdrive. Then there is still the electrical wire mess to deal with. So much time and so little motivation! LoL
Thinking I might name the boat "Cash Drain Hole".
LX Kid
Ensign
I put my trim pump back together just to find out that the screen on the pick-up tube is no good. Does anyone have an idea where I could get some super fine screen to make a new one. If I could find some I could put it over the pick-up and secure it with some safety wire. I know lawn mover carbs have similar screens but don't think it would be large enough.
"Oh WoW!" The "Working" warning seems to be fixed. Thanks iBoats programers!
LX Kid
Ensign
Pretty sure I found something that will work. "Hope wifey doesn't look for it." Found this strainer in the kitchen and all I have to do is cut the screen out of the frame.
Click image for larger version  Name:	strainer.jpeg Views:	1 Size:	2.6 KB ID:	10523567
Jcris
Hey
Lost track of you with the new website changes. How's it going with the project?
redneck joe
that tool is one of the best things in my kitchen; i would definitely notice it missing.
chevymaher
LOL I learned years ago leave her kitchen stuff alone. If i see something I can use. I make a trip to the Goodwill. They got that stuff for 50 cents or so.
Baylinerchuck
If I had a nickel for every time my wife came into the garage and found a kitchen implement sitting on my work bench.....LOL!! :behindsofa:
LX Kid
Ensign
What can I say about progress on the boat? Xmas, food, visiting etc and now weird cold weather moved into Florida. Dang it 34degrees out there right now! Do you really think that I'm so hard core that I would get out there and do anything on the boat? "NOT ME!"
I did put the trim pump back together and tested it out. Found that one relay way bad. Ordered off ebay for $9 delivered and it seems to work great on the bench with no hydraulics on it yet. Speaking of hydraulics, what's recommended fluid used the in the SAE J1171 pump? Oil, trany fluid, etc? Not gonna use that expensive Quicksilver stuff.
chevymaher
Same pump mine has. 30W engine oil is what I found they said to use. Seems to be what was in it when I got it.
LX Kid
Ensign
Being it was a nice day outside, I got motivated to work on the wiring. Took about 3.5 hours to get everything routed and sorted out.
Can someone tell me how the special bolt, collar and spring attach to the pilot arm? I didn't remove it so I can't figure out how it bolts on. Manuals don't really show anything. Also on the other end, of the long rod, where it attaches to the hydraulic ram is frozen or is it supposed to be that way, 3rd pic? I'm betting that it's supposed to rotate with the movement of the hydraulic ram.
LX Kid
Ensign
Next is to torch the old motor mounts off and put the new ones on. The old ones are rusted beyond belief. They are almost one solid mass of metal. I'll need adjustable mounts when I start doing the gimbal assembly to the motor alignment. 20180116_135133_resized.jpg
LX Kid
Ensign
I soaked the end with PB Blaster for a week and still doesn't budge. Gonna take a small ball peen hammer and tap it out of the hole and see what's to be done.
LX Kid
Ensign
Nobody knows what the correct assembly of this bolt and parts to the pilot arm??? There is a bolt, collar, spring,washer and nut that attaches to the gimbal pilot arm.
