J-24 Prop Maximization.-
Sea Rider
We're finishing painting a J-24 sailboat which will be powered by a 2 stroke Tohatsu 18 HP long shaft engine. This model revs 5200-5800 factory stated rpm. The standard delivered prop is a 3 blade 9 pitch prop which peforms excellent in light to medium aplications. Being a J-24 a heavy 1.5 ton sailboat without crew was wondering if it would be fine to go for a prop max for wot rpm to be at or around full wot numbers if that's possible playing with prop pitches.
A J-24 only achieves fast displacement speeds, but won't it be nice to count with full rpm in case you need them ? Should it be tached lightly loaded or with its 3 crew adult members ?
Happy Boating
Sea Rider
For that will need to wait untill the paint is done and the engine has ended its break in period before going wot lightly loaded moving such a weight.
Happy Boating
steelespike
If it helps any the 18 2 stroke at 2-3 hours break in suggests 1 minute of wot every 10 minutes,
3-10 hours suggests 2 minutes wot every 10 minutes.That should give plenty of time to evaluate the setup
So you don't have to waste 1/2 the season getting an idea what prop is needed.
