Re: % J/E & Merc posts
It isn't that bad to swap reed valves out on an inline Merc. You do not have to mess with the crank or any of that, you just pull the powerhead, split the case, unbolt the reeds, put the new ones on, and reassemble. If you are being charges 1500 to have reeds replaced, then you need to look for another shop. That being said, you don't have to remove the carbs or any of that. I needed to reseal the case on an old inline 6 Merc I had, and I had the powerhead off, split, sealed, and back on in an afternoon. Didn't even have to touch the carbs. It isn't that hard to work on Mercs. <br /><br />Mercury was always a more performance oriented motor, meant to blaze across the water wide open all day long. It appealed to the speed set. Johnyrudes were happier not running wide open all day. You could putt around if you wanted, they apealed to the fishermen/casual boaters. You can do that with a Merc as well, but they do like to be above 3500 rpms. As to which one was a more quality motor, that will always be as debatable as Ford vs Chevy. All I can say is I have never owned a Merc built after 69, and they have always ran great. In my opinion, if it is cared for, it doesn't matter which one made it. I see more johnyrudes around than old Mercs, but that is fine, as I tend to be passing those johnyrudes anyway. I myself am biased towards Merc...
