Re: j225txcub cooling question
thanks guys, just ordered the parts. will be replacing all parts in water pump and also T-stats.
Just letting you guys know I just purchased this boat, and look likes it has not had any work done to it for many years.
Compression is 100 + in all 6. I started it up yesterday and started right up.
There was no alarms are anything, but started to see really hot water pouring out of the 2 holes under the power head.
The water was steaming. I checked the stats and pulled them out. There was no flow coming from the open stat port.
Do you know if you don't have pressure that the water will pour out of the 2 holes???
There was no alarms are anything, but started to see really hot water poaring out of the 2 holes under the power head.
Do you know if you don't have pressure that the water will poar out of the 2 holes???
Larry
