kbait
- Joined
- Nov 13, 2007
- 2,484
2000 5hp Johnson. Tell-tale only squirt when revved up a bit. Changed impeller and same thing (old one wasn't too bad..) This motor has a flush plug under powerhead. If I take that plug off, and run it, water gushes out nicely. If I plug it w/my finger, it gets a bit pressurized, and if I rev the motor, cooling water (hot) comes out the telltale. Telltale tube/grommet isn't obstructed.
Question: Water obviously is obstructed through powerhead, and I don't see a thermostat.. where to look? Also, it seems to have a hard-tube connection from waterpump housing to powerhead, so I don't think it's a bent rubber grommet..
Thanks.
Thanks.
