Last week I ran a full decarb on my 1984 J90, then ran a compression test with all 4 cylinders showing between 120 & 125psi. I then fitted a new set of plugs and took the boat out yesterday for a spin.. Top end speed was a little off so back at home I checked the plugs to find the plug in Cyl 1 looking like new and wet.. I'll check the coil/spark today but am not sure why the plug is wet or how water could get in there if the compression tested ok. There was only a small amount of water on the plug did not look of feel like the cylinder was flooded. any idea's?
