jabsco head pump just clicks
20002760
When I push the flush button the motor tries to turn but just clicks. I can turn it with a screwdriver and sometimes get it to pump. It does not turn easy though.
Do I need a new pump? or
Do I need the rebuild kit? or
Is the motor not getting enough power?
smokeonthewater
Re: jabsco head pump just clicks
I just played this same game with my jabsco macerator pump... the impeller has a plastic hub with rubber molded around it... On mine the plastic hub had cracked causing the while thing to expand just enough to jam when trying to pump.... Swap the impeller and you'll likely be good to go.... btw rubber gloves are HIGHLY recommended
20002760
Thank you. I just got the repair kit in the mail yesterday. Guess I'll be getting dirty today. I will report results so that the next person with the same problem can benefit.
20002760
Just finished installing repair kit. Works great now!!
