bonz_d
Thread starter- Joined
- Apr 22, 2008
- 5,276
Just wondering -- If you trimmed the motor in another notch (if there is one), the AV plate might end up horizontal to the water when on plane. Mounted as it is, thinking it may end up trimmed out on plane, kicking up the spray.
The second hole is level with the bottom, one hole down would be negative trim. Already checked. Also the AV plate is 3/8" above the bottom of the hull now. Well going to pick-up a short shaft motor tomorrow so I'll see what happens.
