StratosRob
Thread starter- Joined
- Sep 8, 2006
- 93
I have a 1988 Johnson 90 Vro V4.I have fire on all 4 cylinders but when I pull number 4 plug wire off I have no change in RPM but alittle nothing like when I pull the plug wire off any other cylinder.When I pull the wire off any other cylinder(1,2,3) the motor drops RPM and just about dies.I cleaned the carbs. no change.The compression is 120 on all cylinders. The #4 plug looks real wet(fuel) compared to the other ones. Running 87 Octane quicksilver synthic. Blend. The vro is disconnected 50:1 pre mix coils omhs ok,wires ok,new plugs,sensor coils oms out ok could this be a power pack going bad. Thanks for any help.
